i want to be able to download and store files (eg. for ifu), but i dont want to use an SD-card. I have a flash module:
http://www.ghielectronics.com/docs/71/flash-module
but I’ve only been able to find examples of this being used with gadgeteer. Is it possible to use this on a G120? I’m currently working on a G120HDR, but from what I understand this can’t use any gadgeteer-dependent stuff?
I’ve seen that the GHIElectronics.NETMF.IO V4.1.8 has a PersistantStorage class that can take “NAND” as constructor argument, but there arent any examples of this. Does this have any counterpart for the G120 and, if it does, do you have any examples of a flash component that could be used?
If you can’t use NAND as persistent storage, do you know if there is any type of sd-card that can be soldered to a board directly, so that you don’t have to insert one on every single module?
Thank you
