http://www.worldcarfans.com/113122067794/mercedes-joins-the-smartwatch-fray-teams-up-with-pebble
That can be very good for pebble.
With heads up displays and voice announcements, I donât think a watch is a viable information source in an automobile. Taking your eyes away from the road can not be a good thing.
And even those are plenty distracting.
They might be, but voice and heads up are the choice for military jets.
Iâm going to turn my wrist which is attached to the hand hanging onto the steering wheel to see something, Iâm thinking maybe not the best choice, but it will sell for no other reason then being a hipster status toy.
True, better than the alternative, but jet pilots arenât getting emails and texts and sports scores updates on their HUD.
Well, I hope, at least.
Note: Iâve never flown a fighter jet, and I donât have a HUD in my car, so I donât know what shows up on the displays.
Voice in a fighter jet is an interesting thing as its only used for really bad stuff and its a little more complex then that as it uses a female voice (or it used to) as men tend to pay more attention to a female voice, but having been out of that game for awhile Iâve wondered about the influx of female pilots and how âvoiceâ changed because of that. Interfaces in fighter jets are very carefully designed with an concept you use every advantage you can, because if you donât the other guy will and you might loose because of it. At the end of the day pilots used to turn some of it off as frankly it could be overwhelming. What do you really need to know and why and this problem is in our every day lives now. Do you really need to know sports scores while your making a lane change on the highway during rush hour, be a fighter pilot, turn the dam thing off.
On the Amp Hour podcast a week or so ago, Andrew Witte from Pebble was the guest, and mentioned in passing the Mercedes integration. If you real the press info above, itâs clear that most of those scenarios theyâre enabling are while youâre external to the vehicle - Andrew explicitly mentioned the unlock as you approach scenario (which obviously only works within BT range). And the only âwhile drivingâ option they talk about is traffic alerts which do make sense to me.
The bigger issue in my view is the scenarios you all talk about are real distractions that arenât Merc specific, but are possible, if you choose that. A more optimal solution might be to know youâre also paired to the car at a point in time so you filter out anything other than âcriticalâ alerts and only use passive feedback rather than displayed data.
