Hello,
This might not be 100% Fez related but it will probably save me from asking the question in the future. When you have a thread you can only pass in one parameter so I passed in a object array. Lets say the array has data of the textbox, how can I do the following example with threading
public void GetIpInfo(string url, WebBrowser b)
StringBuilder sr = new StringBuilder();
sr.Append(url);
b.Navigate(sr.ToString());
public void GetIpInfo(object array)
object[] data = array as object[];
//the webrswer control to use is in the object array, how can I do it as shown in the first example
You don’t need to pass variables to the thread function. Make the function part of a dedicated class, and you’ll have access to all the class members.
See my implementation of the abstract ascii line processor on codeshare: http://www.tinyclr.com/codeshare/entry/457
Rather than pass an object array, you can pass an instance of a class. For example (This is not tested, I just typed it up here so consider it pseudo code)
class MyThreadData
public string Url {get; set;}
public WebBrowser Browser {get; set;}
// Create the MyThreadData instance and populate it
MyThreadData theData = new MyThreadData(){Url="...", Browser = theBrowser};
// Create the thread
Thread myThread = new Thread(new ThreadProc(GetIpInfo));
// Start the thread passing the instance of the MyThreadData
myThread.Start(theData);
public void GetIpInfo(object state)
MyThreadData data = (MyThreadData)state;
// use data here...
