After having to install a new windows setup, i am trying to get my deployment environment working. VS2010, .NETMF4.2, GHI.NETMF4.1 are already installed. MFdeploy can ping successfully, but trying to deploy the old solution, i get a
Thank you very much for your answer.
Under Win7 i installed now ghi.net4.1, but now i even get any response from panda: usbizi-updater says no response from device. Now the devmgr tells me there is a USBizi, but the driver is missing…
thanks for these hint.
i got only VS2010, but i installed NETMF 4.3, the GHI 2016 SDK and GHI 4.1 2012 R0 SDK,
Now p2 is recognized onusb, i can create a new panda2solution, but i instantely get a ‘this project type is not supported within this installation’. Same when trying to open an old solution…
@ Mark15 - If your project used the old board-specific templates, those are no longer supported and may not get installed with the last NETMF 4.1 SDK available. If you are using them, you will need to create a new Micro Framework Console Application project, copy your code over, and re-add the old references.
@ glx:
the only installed project template for MF is a BrainPad.NET Application… on creating a new app than i get an error ‘there is missing a project subtype…’ and creation is aborded
@ John:
i think i didnt get you - how can i use the old references, if they are not installed?
@ Mark15. I’m not sure we get how you’re trying to do whatever it is you’re trying to do. Can you step us through creating a new project? The workflow should look like, open VS2013, create new project, set it’s type from the “templates” section to “Micro Framework”, “Console application”. If you can’t see “Micro Framework” in the list, you’ve not followed one of the steps - the one where you run the VSIX.
@ brett:
i can not see any tamplate except a brainpad app
i tryed now several combinations of vs, .netmf, ghimf and nothing worked. Either i can see the templates or i can see p2 on usb or i can open a solution, but no setup did it’s job. :’(
ok, once again: i want to develop&debug&deploy several applications with the p2 under win7
i don’t want to throw the boards to trash and port the project to other platforms…
is it possible to run the p2 under win7? what are these steps?
Please remove all the components you’ve installed, including Visual Studio 2013
Please step through the setup instructions .NET Micro Framework – GHI Electronics and make sure you note how each one completes.
Then, please open VS and show us a screenshot of the “New Project” page, before you’ve attached your Panda2 to the computer. If the software install was carried out successfully and there were no issues then you should see the netmf templates. But we need you to be deliberate about the steps and help by giving us all the information we ask for.
That’s perfect. Exactly what you need. As was pointed out on Page 1, the old “quick start code” samples that were for a specific board are no longer provided. All you need is to select the console application template, and add the references you need, copy over your code, and compile.
