Is the LDR Button exposed to a pin between Di5 - Di12?
I am using those as an OutputPort, and wanted to use the LDR button for tripping a sensor(to test with manually).
When I run the program one of the pins goes high then shuts off. I could figure it out, but I just wanted to make sure that’s what is going on.
I am only assuming that I am using the same pin twice here.
I thought I saw it somewhere on here, but couldn’t find it. Nor could I figure it out reading the schematics.
Long term it won’t matter because I will be using the other IOs with my tinker kit.
If it’s the case that the LDR button is exposed to one of these pins, could we make a note of it on the Panda Brochure?
Mike in MN
