I’ve a Panda II with network shield and a thermometer in AN3.
If I reference in my VS project the assembly GHIEelectronics.NETMF.Hardware (required to run the Thermometer), every time I try to start debugging I’ve the error "“the debugging target is not in an initialized state; rebooting…” and the VS stops.
If I remove the assembly (and Thermometer code, of course), the project will start.
The board is new, just received yesterday.
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.5.1
SolutionReleaseInfo.solutionVendorInfo: GHI Electronics, LLC
SoftwareVersion.BuildDate: Apr 11 2011
SoftwareVersion.CompilerVersion: 410561
Ths SDK is the last one.
I’m powering via USB cable.
The code is really stupid:
namespace FEZ_Panda_II_Application1
// Blink board LED
bool ledState = false;
OutputPort led = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.LED, ledState);
FEZ_Components.Thermometer myThermometer = new FEZ_Components.Thermometer(FEZ_Pin.AnalogIn.An2);
int temp = myThermometer.GetTemperatureCelsius();
// Sleep for 500 milliseconds
Thread.Sleep(500);
// toggle LED state
ledState = !ledState;
led.Write(ledState);
