What physical size (eg 5.1mm x 2.0mm) is the external power connection on the Panda II ?
I looked at the Netduino and Netduino Plus schematics. The Barrel Power Jack they use is 2.1mm ID, 5.2mm OD.
I was not able to find a similar notation on the Panda II schematic.
Thanks!
Scott
PS - As long as I’m asking about power, I plan to get a 6V,1A power supply. Any problems with that? Can I increase the voltage without causing problems with (ie, smoking) the voltage regulator?
