I am trying to have the Panda access the SD card when the button is pressed. The problem occurs when I try to unmount the SD, so that program does not crash the next time I press the button. However I always get the following message (even when I put a sleep delay):
Error Message:
#### Exception System.IO.IOException - CLR_E_FILE_IO (4) ####
#### Message:
#### Microsoft.SPOT.IO.VolumeInfo::.ctor [IP: 0000] ####
#### Microsoft.SPOT.IO.RemovableMedia::MessageHandler [IP: 0022] ####
A first chance exception of type ‘System.IO.IOException’ occurred in Microsoft.SPOT.IO.dll
An unhandled exception of type ‘System.IO.IOException’ occurred in Microsoft.SPOT.IO.dll
By putting in the debug print commands, the error appears after the unmount and dispose.
What is interesting is that when I remove the unmount and dispose lines it works fine the first time, but crashes when it tries to remount the sd the second time I press the button.
Here is the code that I am using, and would appreciate any help or advise.
using System.IO;
using System.Text;
using System.Runtime.CompilerServices;
using Microsoft.SPOT.IO;
using GHIElectronics.NETMF.USBHost;
static InputPort sdDetectPin = new InputPort((Cpu.Pin)FEZ_Pin.Digital.Di50, false, Port.ResistorMode.PullUp);
static PersistentStorage sd;
// Subscribe to RemovableMedia events
RemovableMedia.Insert += RemovableMedia_Insert;
RemovableMedia.Eject += RemovableMedia_Eject;
// Subscribe & Mount USB Memory
USBHostController.DeviceConnectedEvent += DeviceConnectedEvent;
// Create Button object assigned to the a Button Component connected to Di2 with interrupt feature
FEZ_Components.Button myButton12 = new FEZ_Components.Button(FEZ_Pin.Interrupt.Di2);
// Assign a method to run when any event happens with the component.
myButton12.ButtonPressEvent += new FEZ_Components.Button.ButtonPressEventHandler(myButton12_ButtonPressEvent);
// For When the button is pressed
static void myButton12_ButtonPressEvent(FEZ_Pin.Interrupt pin, FEZ_Components.Button.ButtonState state)
if (state == FEZ_Components.Button.ButtonState.Pressed)
// Check is SD Card is in
bool sdExists = sdDetectPin.Read();
if (sdExists == true)
// Mount SD Card
if (sd == null)
sd = new PersistentStorage("SD");
sd.MountFileSystem();
Debug.Print("New SD card is mounted");
Debug.Print("");
Thread.Sleep(5000);
sd.UnmountFileSystem();
Debug.Print("SD card has been unmounted");
Debug.Print("Old SD card is still mounted");
Thread.Sleep(5000);
Debug.Print("Old SD card has been unmounted");
Debug.Print("No SD inserted");
Debug.Print("End of Button Press");
static void RemovableMedia_Eject(object sender, MediaEventArgs e)
Debug.Print("Storage \"" + e.Volume.RootDirectory + "\" is ejected.");
public static partial class FEZ_Components
public class Button : IDisposable
InputPort button;
public Button(FEZ_Pin.Digital pin)
button = new InputPort((Cpu.Pin)pin, false, Port.ResistorMode.PullUp);
public Button(FEZ_Pin.Interrupt pin)
button = new InterruptPort((Cpu.Pin)pin, true, Port.ResistorMode.PullUp, Port.InterruptMode.InterruptEdgeBoth);
button.OnInterrupt += new NativeEventHandler(OnInterrupt);
void OnInterrupt(uint data1, uint data2, DateTime time)
ButtonState state = (data2 == 0) ? ButtonState.Pressed : ButtonState.NotPressed;
ButtonPressEvent((FEZ_Pin.Interrupt)data1, state);
public void Dispose()
button.Dispose();
public enum ButtonState : byte
NotPressed = 0,
Pressed = 1,
public ButtonState GetState()
return (button.Read() == false) ? ButtonState.Pressed : ButtonState.NotPressed;
public delegate void ButtonPressEventHandler(FEZ_Pin.Interrupt pin, ButtonState state);
public event ButtonPressEventHandler ButtonPressEvent = delegate { };
