Panda II Power Question
When I have my Panda II plugged into a USB port and also plugged into a Wall Jack, which power source does it use? Is there a way to make sure it is only using power from the jack?
Thanks!
Checking the schematic, I think you can insure that power comes from the 5V regulator, which is feed by Vin, instead of the USB, if you remove diode D4 from the circuit board.
