We have problems with our panda II dying because the voltage regulators become overheated. With everything plugged in we measure around 600-700mA of curent. But if we disconnect everything, the panda alone draws around 450mA! This seems way too much, since the specifications for the USBizi says it should only draw 100mA with everything enabled.
Have we destroyed something or what could be wrong?
When excess voltage is applied to a MCU pin it is toast. I/O could be 5v tolerant but not beyond that. Afer applying excess voltage or even subject to a stray high voltage like a ESD or random high voltage strobe, the MCU is gone.
At this point measuring current drawn or chip temperature does not help. Check the board for any further damage, rectify and replace the USBizi
