I Just tried adding the USBHost code from wiki to my program as I wanted to try out using a USB keyboard. In my program I have a serial display connected to COM2 which worked fine before I added the USB stuff. The code I added was
USBHostController.DeviceConnectedEvent += DeviceConnectedEvent;
USBHostController.DeviceDisconnectedEvent += DeviceDisconnectedEvent
static void DeviceConnectedEvent(USBH_Device device)
Debug.Print("Device connected...");
Debug.Print("ID: " + device.ID + ", Interface: " +
device.INTERFACE_INDEX + ", Type: " + device.TYPE);
static void DeviceDisconnectedEvent(USBH_Device device)
Debug.Print("Device disconnected...");
Now when I try and deploy my code I get an error message
An unhandled exception of type ‘System.InvalidOperationException’ occurred in GHIElectronics.NETMF.USBHost.dll
and the message “ERROR starting up” is displayed on my serial display. I don’t know what is happening. Do I have to get and run the driver for a virtual com channel? I assumed that because I was using COM2 connected to the panda I wouldnt need to.
Thanks for any help
Alan
