Here is my first robot project using a FEZ Domino. Based on the Dagu 2WD beginners robot chassis and a Sparkfun Ardumoto board. Details can be found on the (link removed).
Being an Arduino user for many years this is a great step ahead for me using FEZ and .NETMF.
@ fokie I have to thank you for the Ardumoto library and the patch.
@ chris The Maxbotix is a great sensor for a mid range from 15cm to 1m. It has 3 interfaces analog, digital and RS232 which is great if your board lacks on free pins.
Don’t have any experience with the long range sensors. The EZ1 should work upto 6,45m (256inch) but this doesn’t work on a small robot. The beam gets to wide at greater distances than 1m, detecting false echoes from floor reflections.
The obstacle avoiding program should do something like that (theoretically):
Detect object with the front sensor
turn left until front sensor did’nt see an object anymore
Now the side sensor takes over and keeps a constant side distance to the object
When the line sensor sees a line, abort the process.
But in practice its more difficult. I must confess, that the video doesn’t show this behaviour. Because the right motor of the robot is slower than the left one, it doesn’t turn well in place. Instead the robot is making a step backwards and make a long curve around the object.
I need to change the motors or have to add an offset between the motor speed in software.
in fact, obstacle avoiding is a very difficult part of a robot. Because it would have to constantly check whether or not there is something in front of it.
Look at this example:
There is a box in front of it. It could either go left or right around it. Let’s say left is clear. But right is not. So it drives right, it sees even mores boxes. It should then decide to check out the left side. The left side is clear.
It should decide and remember what to do to make this as functional as possible.
You should try a Maxbotix EZ4 if you’re having beam spread problems.
@ Chris that brings up a point I didn’t consider - the EZL (long range) ones only have EZL0 and ELZ1 which have a fair amount of beam spread. Our bots may be too close to the ground even with a pillar for sensors to get accurate readings. Hmm. Testing required. And more money spent.
No, I don’t have beam spread problems. The EZ1 is fine for me. I’ve found a bug in my program :-[, now it works like a charm.
New video is online:
[url]http://www.youtube.com/watch?v=Xw_46NPSzuo[/url]
Now the robot is doing what the programmer meant to do it.
