after a very short time (less than a minute or two)
First I used C# functions to handle the strings and then I wrote a function by myself but it didn’t help.
Here is a sample of my code:
static void SerialUSBThread()
byte[] data = new byte[128];
int len;
string buffer = "";
string sentence = "";
try
len = serialUSB.Read(data, 0, 128);
for (i = 0; i < len - 1; i++)
buffer += array[i];
for (i = 0; i < len; )
// find start of a sentence
startIndex = buffer.IndexOf('$', i);
if (startIndex == -1)
break;
// find the end of a sentence
endIndex = buffer.IndexOf('\r', startIndex);
if (endIndex == -1)
break;
sentence = "";
sentence = buffer.Substring(startIndex, endIndex);
// if sentence wasn't recognize well, skip it and read new one
if (gpsInfo.Parse(sentence) == false)
break;
// Skip to next sentence in the buffer
i += sentence.Length;
catch (Exception ex)
Debug.Print("Message: " + ex.Message);
Debug.Print("Stack Trace: " + ex.StackTrace);
Debug.GC(true);
I though to replace the IndexOf() function with mine function, like that:
public static int FindChar(string buffer, char cToFind, int index, int len)
for (; index < len; index++)
if (buffer[index] == cToFind)
return index;
return -1;
But it didn’t help.
Beside this process I don’t do anything yet with the GPS info and I don’t know how can I continue if I get this exception all the time.
Can you advise?
The code you are showing wouldn’t use all memory! something else must be using the memory.
Check what assemblies you have added to your project and try to clean up the code.
This is the printing that I got before the exception:
GC: 1msec 31452 bytes used, 32928 bytes available
Type 0F (STRING ): 9516 bytes
Type 11 (CLASS ): 1896 bytes
Type 12 (VALUETYPE ): 72 bytes
Type 13 (SZARRAY ): 1404 bytes
Type 15 (FREEBLOCK ): 32928 bytes
Type 17 (ASSEMBLY ): 13668 bytes
Type 18 (WEAKCLASS ): 48 bytes
Type 1B (DELEGATE_HEAD ): 612 bytes
Type 1C (DELEGATELIST_HEAD ): 96 bytes
Type 1D (OBJECT_TO_EVENT ): 96 bytes
Type 1E (BINARY_BLOB_HEAD ): 360 bytes
Type 1F (THREAD ): 1152 bytes
Type 20 (SUBTHREAD ): 144 bytes
Type 21 (STACK_FRAME ): 1128 bytes
Type 27 (FINALIZER_HEAD ): 72 bytes
Type 31 (IO_PORT ): 72 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 1044 bytes
Failed allocation for 769 blocks, 9228 bytes
Regarding the assemblies, I think I reduced them to minimum.
I use:
System System.IO
mscorlib
Microsoft.SPOT.Native
Microsoft.SPOT.Hardware
GHIElectronics.NETMF.System
Does Print.Debug use a lot of memory?
Is it possible that debugging with breakpoint can cause it also?
it is showing “32928 bytes available” so you have 33KB of free memory. This is plenty to do everything! Check the line that is causing the exception. Maybe it is trying to create some huge object that it shouldn’t…like a very large string.
char[] array;
string buffer = "";
len = serialUSB.Read(data, 0, ComBufferSize);
array = System.Text.Encoding.UTF8.GetChars(data);
// This line was missing - so the buffer get bigger and bigger
buffer = "";
buffer += array[i];
BTW, is there a better way to convert byte[] to string?
There’s a constructor for String that can simplify your code. The snippet below should work for you. Doing string concatenation using “buffer += …” should be avoided if possible, as this is an expensive operation even in the full .NET framework. Hope this helps.
string buffer;
buffer = new string(
System.Text.Encoding.UTF8.GetChars(data),
0,
len);
Once you “new” up the string object in each loop, the GC will take care of the “old” string for you. There’s nothing else you need to do for cleanup. In full .NET and .NET Compact, we have the StringBuilder class to help us do efficient in-memory string manipulation, but that class hasn’t made it to MF. I’d recommend going to MSDN and reading about how System.Strings are handled in C#. Most of the info you find will be applicable to the Micro Framework.
Adding on, to explain strings in few words. Strings are somewhat constant object. Once you create a string it can’t be modified. So you use += (concatenate strings) you are actually creating new string behind the scene.
string str1 = "FEZ";
string str2 = "Easy";
// this code will make a "new" string then leave old "FEZ" for garbage collection
str1 = str1+str2;
