I am looking for OneWire X1 module, but I can see, this gadgeteer is discontinued. Could you tell me why? How can I manage future projects that includes oneWire devices without X1 interface?
Can I use oneWire X1 module in NETMF 4.3 somehow?
My other question regarding onewire is the following. I have installed the latest GHI 4.3 Package and started a new project. Added all the required references OneWire Class (Microsoft.SPOT.Hardware) | Microsoft Learn
but I can not access OneWire… The MSDN api says there is but I can not find it.
You can contact GHI and ask if there are any OneWire X1 modules left.
or
You can ask GHI to manufacture those models for you (I believe your order will need to be at least 100 units).
or
You can manufacture that module yourself (schematics are available) - that module is not very hard.
Of course there are some other options, but I guess those are the main ones.
kind of. Attaching the pull-up resistor will certainly mean it behaves like the one-wire module does. You just need to use the pull-up resistor between the onewire data pin and the 3v3 line, and connect the other two pins of the onewire chip to 3v3 and GND. You can see the schematic http://www.ghielectronics.com/downloads/schematic/OneWire_X1_Module_SCH.PDF
