Onewire only works on DI2 and DI3
I have a problem concerning onewire on various digital pins. I am using a DS18B20 and the provided example.
This works fine for Di2 + Di3
Cpu.Pin p = (Cpu.Pin)FEZ_Pin.Digital.Di2;
OneWire ow = new OneWire§;
But not for any other pins.
When I request a temperature conversion, it never returns!
I have tried to put a LED on for example Di0 and I can control it without problems, but OneWire will not work.
I need to be able to use other pins.
Can anybody help out, please?
You will need a pullUp resistor for Onewire bus. Di2 and Di3 has pullUps becaues they can be used for I2C. A pullup resistor of 1.5-5kOhm is required.
Thanks a lot for your reply.
I get the resistor.
You should use 4.7KOhm, see the sensor datasheet.
