How can i write one event for multiple buttons using the object sender
e.g.
if(sender is btn1)
do something;
if(sender is btn2)
do something
is it possible to use sender for this purpose. if so can i get an example
e.g.
if(sender is btn1)
do something;
if(sender is btn2)
do something
:). i just answerd my own question.
i dit not think that it was so simple
Hi
I´m a very experience .net programer. It´s no correct (best pratic) to use one method to receive all event, if you can, read about oriented object programming. Make like this:
protected void btn2_TapEvent(object sender)
txtMatricula.Text += “2”;
protected void btn3_TapEvent(object sender)
txtMatricula.Text += "3";
I have to disagree with you. What part of OOD does this violate?
It is a lot easier to read code with a limited of interrupt handlers that act as dispatchers.
