Hello,
I have new FEZ Connect Shield V1.5. One PIN (DI4) is not smooth as other pins. Please te a look at the atteched photo for details. Is that OK and can I plug this shield to Panda without any risk to damage it?
Thank you for your help
Hello,
Looks like a bit of stray solder. You can remove it with a solder iron or some sharp straight edge snips. If it goes into your FEZ board header fairly easily, it’s probably fine. Don’t force it into your FEZ board.
If that doesn’t work, try a metal file.
Thank you for your help and very quick response!
