Sorry. Itās ābasically proā for the majority of folks. Itās not limited in the ways the previous free versions were. It has just about anything the majority of independent/enthusiast/hobby developers will need.
The whole file system is on the SD card on Pi2 (MinnowBoard Max has additional options). Are you asking about mounting an additional card using a SPI or I2C -based adapter? If so, Iām not sure what we may do there long-term.
No, I mean, can I create files on SD card to store, for example, logs? I find Windows.Storage.IStorageFile interface, but canāt find an implementationā¦
EDIT: On the same SD card that Windows 10 is installed to.
I havenāt tried it yet on the Pi, but will. You get an IStorageFile, usually in the form of StorageFile, as the result of a file create or open operation on a folder object.
Remember, when looking for help on this stuff, you can look at general Windows 10 (or in many cases, Windows 8.1) APIs. Windows 10 IoT Core just uses the same set of APIs for most things, and adds in long-running background tasks, the GPIO stuff, and in the future, also some other helper capabilities to make up for not having (for example) wifi connection dialogs.
I canāt speak to futures, but itās more that this is the core of what we consider to be IoT capable, and if you want more features, youād use one of the uplevel SKUs (mobile, desktop/enterprise).
And yes, certainly OEMs could build upon this to add more features/capabilities/drivers etc.
I was previously able to install the Win 10 ADK on my Windows 8.1 machine. From that, you can use dism to get the FFU onto the card. Itās not supported, though.
But you canāt program for the Pi on 8.1. You can do it in a VPC, though.
You may get some hack to work to let you use the UWP and IoT Core SDK on 8.1, but itās not at all supported or recommended, and itās not guaranteed to work at RTM (or any other time).
You can dev for the Pi using Windows 10 in a virtual PC hosted in Windows 8.1 if you want. I did that for months.
Iāve tried, but Windows 10 on my VirtualBox was consuming literally [em]everything [/em] on my 8-core machine, and was still painfully slow. I have no idea why, but it was unusable. What do you use to virtualize Windows 10?
For me, VMWare, because it virtualizes USB and that means I can even do the SD-Card stuff from the VM. I run a quad-core system with 32Gb of memory and I think I gave those VMs 6 or 8Gb of memory. Be sure to give it enough memory as that will definitely slow things down if you donāt. I have two Windows 10 VMs in this configuration and for me they work well enough for comfortable daily use.
I used Hyper-V. I have 24gb RAM on this 6 core PC. Memory is the big deal when virtualizing PCs. Running a virtual PC on my 8gb Surface Pro 3 was painful.
I gave it 6 cores and 8GB RAM, and it wasnāt enouh (actually, there was plenty of free RAM, but CPU was utilized 100% almost full-time). Maybe Iāll give HyperV a go.
As you have noticed: dism doesnāt support SD cards on Windows 8.1. Youād have to install the Windows ADK for Windows 10 (e.g., from here, at the bottom: Download and install the Windows ADK | Microsoft Learn ). I tried it and was able to use the included version of dism located at "c:\Program Files (x86)\Windows\Kits\10\Assessment and Deployment Kit\Deployment Tools\x86\Dism" to transfer the IoT Core on my RasPi. 8)
