Hello,
I am still getting errors with my OLED v1.1
Mainboard: Hydra 4.2 (full info below)
I can display an image in both JPG and BMP and the v1.2 OLED displays it as expected.
The v1.1 OLED shows the same image staggered (for both JPG and BMP)
Also for some reason I get an exception on GIF (but I guess that is a different issue) – anyone got Gif working on Hydra + OLED?
I have attached the display output. The picture is static and not flickering as you may thing from the images, it is just more like a timing issue.
Mainboard:
DeviceInfo:
HAL build info: 4.2.0.0, Microsoft Copyright (C) Microsoft Corporation. All rig
OEM Product codes (vendor, model, SKU): 255, 0, 65535
Serial Numbers (module, system):
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Solution Build Info: 4.2.3.1, Copyright (C) GHI Electronics, LLC
AppDomains:
default, id=1
Assemblies:
mscorlib,4.2.0.0
Microsoft.SPOT.Native,4.2.0.0
Microsoft.SPOT.Hardware,4.2.0.0
Microsoft.SPOT.Graphics,4.2.0.0
Microsoft.SPOT.TinyCore,4.2.0.0
Microsoft.SPOT.IO,4.2.0.0
System.IO,4.2.0.0
Microsoft.SPOT.Hardware.Usb,4.2.0.0
Microsoft.SPOT.Hardware.SerialPort,4.2.0.0
Microsoft.SPOT.Touch,4.2.0.0
Microsoft.SPOT.Ink,4.2.0.0
Microsoft.SPOT.Hardware.PWM,4.2.0.1
Microsoft.SPOT.Hardware.OneWire,4.2.0.0
System.Xml,4.2.0.0
Microsoft.SPOT.Time,4.2.0.0
Microsoft.SPOT.Net,4.2.0.0
System,4.2.0.0
Microsoft.SPOT.Net.Security,4.2.0.0
System.Net.Security,4.2.0.0
Gadgeteer,2.42.0.0
GTM.LoveElectronics.Button,1.0.0.0
GTM.Seeed.OledDisplay,1.5.3.0
Microsoft.VisualBasic,1.0.0.0
StickManTest,1.0.0.0
GTM.GHIElectronics.SDCard,1.1.1.0
Gadgeteer.Serial,2.42.0.0
GHI.OSHW.Hardware,4.2.3.0
GTM.GHIElectronics.UsbClientDP,1.1.1.0
System.Http,4.2.0.0
GHIElectronics.Gadgeteer.FEZHydra,1.1.1.0
Gadgeteer.SPI,2.42.0.0
