Is it OK to power Cobra III from USB port?
Using a Cobra III as a development board for a commercial project with a RS21 WiFi attached.
I ask because I am struggling on getting stability out of the NETMF application being developed and tested. The application works when interactively debugging, but if put it in a test loop, it fails after about an hour (stalls, displays most of a GC output, and stops updating VS). I know the likely suspect is a memory leak.
But this morning I saw a document on the GHI site about powering through-the-hole boards (I know Cobras are not TTH). Since I am only powering my Cobra III with its USB connection and can’t find any guidance on Cobra power I thought I would seek the forum’s council on this.
Thanks,
Greg
