Hello
I need some input on what I am doing wrong.
Below is the string of commands I used to write “123AB” to a file called FILE1\READ1
It appears to create and write to the file, but the read command get nothing back, it’s the same as the write except an “R” instead of a "W"
Did I miss a command?
16:43:42 [TX] - I D:
16:43:42 [RX] - !00
16:43:43 [TX] - I M:
16:43:43 [RX] - !00
16:44:08 [TX] - O 0W>M:\FILE1\READ1.LOG
16:44:08 [RX] - !00 //appears to have created the file to wright too
16:44:22 [TX] - W 0>5 //setting up to write 5 bytes
16:44:22 [RX] - !00
16:44:26 [TX] - 123AB //the 5 bytes of data
16:44:26 [RX] - $00000005
!00 //??? it responds with send two !00’s
!00
16:44:30 [TX] - F 0 //flush to write it to card
16:44:30 [RX] - !00
16:44:43 [TX] - O 1R>M:\FILE1\READ1.LOG //setup to read that file
//no response from the SD module????????
Thanks for the help
