there is a little problem of understanding
I have a little well working projekt, running jointly with the debugger VB2010-Express
The problem with the debug-version:
running the program, stand alone without a debugger, the program hangs after executeing the “ProgramStarted()” Code.
After a few minutes there is a “buffer overflow” notification on the TE35 - display
I had, well, a more or less similar Problem.
When running with attached debugger my code for TCP/IP communication between PC and board worked fine.
But standalone the connection failed after a few seconds.
The reason:
Without debugger the board works way faster.
In my case an answer with debugger took 200ms, without about 10ms.
My PC sent a lot of requests (as much as possible. With a request every 200ms it (my code) worked fine.
Without Debugger and one request per 10ms the connection on the board side failed and did not answer any more. Not even TCP/IP Ack Messages where sent.
My quick solution was to send only one request evrey 50ms. By this everything was fine.
The conclusion:
The debugger delays a lot of stuff on the board. Without debugger you might run into timing problems like a necessarry delay between two initialization steps.
Thanks,
your hint help to find more information of the problem
some status text on the display, a timer to see if the system is hanging…
I renamed the thrad:
when debugging in VB2010 IDE:
a few NMEASentenceReceived messages in a second
when running stand alone
no NMEASentenceReceived event was handled
buffer overflow after 76 seconds
when running connected with the Deployment Tool
massage in Deployment Tool before "ProgrammStarded"
Using mainboard GHI Electronics FEZSpider version 1.0
show us an image of your Gadgeteer designer, and show us a simple code example that replicates this. seems to me that you have a coding problem that is causing the exception that you need to work around.
you only need a spider/Gadgeteer.Modules.Seeed.GPS/Gadgeteer.Modules.GHIElectronics.UsbClientDP
The programcode:
Public Sub ProgramStarted()
gps.Enabled = True
Debug.Print("Program Started")
End Sub
Private Sub gps_NMEASentenceReceived(ByVal sender As Gadgeteer.Modules.Seeed.GPS, ByVal nmeaSentence As String) Handles gps.NMEASentenceReceived
Dim a As String
Debug.Print(nmeaSentence)
a = nmeaSentence
End Sub
running with the deployment Tool you gettin a buffer overflow after a few seconds
Using code tags will make your post more readable. This can be done in two ways:[ol]
Click the “101010” icon and paste your code between the
tags or...
Select the code within your post and click the "101010" icon.[/ol]
(Generated by QuickReply)
This doesn't seem to be all the code. Where are you setting the handler for gps_NMEASentenceReceived???
here’s th next button to learn. The pencil icon on the top right of your post is the “edit” button. Hit that, of the one that’s got your code, highlight your code, hit the 101010 at the top of the post, and then submit your post again b
if the opening of the serial port to fast (btw by adding a positionReseaved Handler) after the constructor
is called, there never raised the Serial_LineReceived
I added a thread.sleep(200) in the constructor of the gps.cs
the second problem is the serial buffer. Observeing Serial.BytesToRead in the gps.cs demonstrate thera a to many datas from the GPS-Chip.
Are the a possibility to slow the gps down ? I think its the UBX-CFG-RATE command but i don’t find out how its works
