NHD ST7066U Driver?
Does anyone by chance have a NETMF driver for this type of display? Figured I would ask before converting one of the other types of parallel NH displays. Shouldn’t be too difficult if nobody else has yet.
Will be using this in my next design:
https://www.digikey.com/products/en?keywords=NHD-0108BZ-RN-GBW
halfway through with adapting an older parallel driver but am not sure how to use the function table in 4 bit mode.
I bet the same as any 4-bit vs 8-bit display. The same as the code sample in their datasheet. You send 4-bits, then 4-bits.
Ok thank you did not understand that part.
