Yep im just starting with spider but have a little problem.
~Everything look and sounds ok but im getting noting on the screen.
Also when i try and install GHI NETMF v4.1 and .net gageteer.
i keep getting the error no xlm file but the file is in the folder. I can install these but not from the setup.
You have 2 problems so lets fix one thing at a time.
For installation, did you follow this http://tinyclr.com/forum/21/4268/
You mus install 3 pieces of software.
Can you please add more detail about error message? We have 2 types error msg are related to xml file.
also make sure that you didn’t change anything in data.xml file.
I experienced a similar problem.
I had downloaded the program and was viewing the contents of the zip with the file explorer of Win7.
When I double clicked on the setup program I was having a problem.
The solution was to copy the contents of the zip file to another location, and execute the setup from there.
Yes you have to unzip the file first.
