Hi there,
Just received my FEZ Spider kit and pretty much went through all the necessary steps to update my firmware. I am pretty sure it worked, these are the results I get from the FEZ Config tool:
Connecting to device…EMX_EMX
Loader (TinyBooter) Version: 4.2.10.0
Firmware (TinyCLR) Version: 4.2.10.1
I have VS2010, I installed the 4.2 framework QFE2
installed all the latest SDK software from GHI.
I see the following in the device manager when I connect the device:
GHI .NET Microframework USB Debugging Interface
I am able to ping the device and am able to run the emulator console app. I had a small hiccup when I tried the hardware console app, it mentioned that the Hardware assembly was missing and the PKCSII assembly as well. I added them and it worked.
Now for the actual issue…when I try to execute the First Gadgeteer project (the one with the camera) visual studio keeps giving me the following error when I attempt to deploy:
Error 1 Device not found or cannot be opened - USB:Gadgeteer
I saw in the 4.2 read me notes that it mentioned this behaviour might occur so I attempted to redeploy and no luck…I have uninstalled and re-installed everything multiple times.
Here is the Device Capabilities from MFDeploy:
HalSystemInfo.halVersion: 4.2.0.0
HalSystemInfo.halVendorInfo: Microsoft Copyright © Microsoft Corporation. All rig
HalSystemInfo.oemCode: 255
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 65535
HalSystemInfo.moduleSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HalSystemInfo.systemSerialNumber: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
ClrInfo.clrVersion: 4.2.0.0
ClrInfo.clrVendorInfo: Microsoft Copyright © Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.2.0.0
SolutionReleaseInfo.solutionVersion: 4.2.10.1
SolutionReleaseInfo.solutionVendorInfo: Copyright © GHI Electronics, LLC
SoftwareVersion.BuildDate: May 1 2013
SoftwareVersion.CompilerVersion: 410713
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 320
LCD.Height: 240
LCD.BitsPerPixel: 16
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
Please help : - )
