New VS community 2013 / .NET MF?
Hello all,
I have re-installed W10 …
Then i followed steps @ .NET Micro Framework - GHI Electronics in order to use .NET MF .
I’ve allready done it under W10 with the same PC, and it was right.
But now, 1st step : the link to VS 2013 community is “error 404-ed”.
I found VS 2013 Community 2013 version 12.0.31101.00 Update 4 and install it.
Then I follow other steps as usual.
After starting VS 2013, I get an error in both case :
  • Trying to create a gadgeteer
  • Trying to open an existing solution or project (of my current project these were working with VS community 2013 / net MF v4.3)
    from .net Gadgeteer Application Wizard :
As this message propose, I’ve installed .NET MF 4.4(after uninstall v4.3). Still the same message.
Anyone for help ? Am I the first ?
Thanks a lot,
Arnaud
Start from the beginning with the steps we have on the support page and then create a new project as described in getting started. Please let us know at what stage you have a problem.
Goodmorning,
the very first step does not work : the link to Visual Studio 2013 Community is not valid anymore.
Thank you,
Arnaud.
It seems to work for me…
Try to copy the link directly to your browser?
http://go.microsoft.com/fwlink/?LinkId=517284
The link didn’t work for me.
Then I had to go probably here: [url]https://www.visualstudio.com/vs/older-downloads/[/url] , made so registration or so and after this I was able somehow to download it. It was quite confusing for me.
Hello,
clik on the link or copy the adress in my browser is the same. There is a redirection, and the browser write that the file can not be found.
http://download.microsoft.com/download/7/1/B/71BA74D8-B9A0-4E6C-9159-A8335D54437E/vs_community.exe=fr-fr
But this is not the only problem.
I’ve (very probably) another installer loaded in july.
vs_community, 1240624 bytes, Descritpion in file property : Microsoft Visual Studio Community 2013 with Update 4.
It’s seems that this installer didn’t load the same files in july (succeed) and this week…
Thanks,
Arnaud
It doesn’t navigate to a new page - it immediately begins the download (for me) - maybe you have immediate downloads blocked.
@ arnaud.audrezet -
Sorry for the delete. Had the wrong link.
Try this link.
See note on page:
Visual Studio Community 2013 includes Update 4, which is a cumulative update of all previous Visual Studio 2013 updates
Hello, problem solved.
Again, I’ve used an old VS community 2013 that was on my desktop. The problem was not there (but there is a problem @ microsoft for redirection of the link step 1).
I’ve restart installation after W10 reinitialisation again (to ensure be clean). Following carefully GHI steps.
I’m nearly sure that last week, i’ve made a fault step 2 :
I’ve installed MicroFrameworkSDK.MSI, but not netmfvs2013.vsix
Now it works.
Really sorry for disturb you, it was my fault again.
Happy new year,
Arnaud
Hello,
I’m reviving an old thread but I also need to reinstall VS Community 2013 and GHI .NETMF SDK on a new PC.
Where can I find a link to download VS Community 2013 ? It is not longer available on the Microsoft website…
This link actually no longer works :
https://docs.ghielectronics.com/software/netmf/getting-started.html
I tried to install VS Community 2013 with update 4 and it does not recognize .NETMF SDK.
I get the same error as @arnaud_audrezet in his first message…
Anyone for help ? Am I the first since 2016 ?
I tried to download Visual Studio Community 2013 Update 4 with full packages (.iso file) but without success. This version is 12.0.31101.
After VS2013 installing I run ‘MicroFrameworkSDK.msi’ with success.
Then I launch ‘netmfvs2013.vsix’ and I get this following error :
This extension is not installed on any of the currently installed products
I get the same result with VS2013 with Update 5.
Which specific version of VS2013 is NETMF compatible with ?
This is becoming quite urgent, I have marketed products for which I no longer have access to the source code…
I think you should go with 2015 or 2017 if using the release 2016
Hi Dat,
Ok thanks I try with VS 2015 and ‘netmfvs14.vsix’ and I keep you informed.
I don’t understand I get the same error when running ‘netmfvs14.vsix’. The installer find only Visual Studio 2019 and 2022 installed on my computer…
How can I do to install NETMF v4.3 in VS 2013 or 2015 ?
What window OS on your PC? window 10 or Window 11?
I use only Windows 10.
It’s resolved.
I managed to install NETMF project system directly in VS 2015 with “Extension and updates” menu as below :
Did installing the online “.NET Micro Framework project system” work for you? I followed your advice and did the same, but I am not able to get my projects to compile. I’m getting “MMP : error MMP0000: CLR_E_FAIL” on some of them that used to build just fine. My concern with your screenshot is that the online project system says version 4.4.0.0, not 4.3. I’m wondering if this is mismatch is the cause of my problems. Thanks!
GHI never distributed a 4.4 version of .NET MF. 4.3 was the last version release by GHI.
Yes, that’s why I was concerned that installing it from “Extension and Updates” was giving the wrong version (4.4). I don’t think it is the cause of the problem I’m having though.
