I am not a linux junkie so I have to ask.
Using my just received GHI BeagleBone Wireless.
Running using HDMI, Wireless (USB port dongle) Keyboard and Mouse.
I am using a external 5 VDC 2.5 Amp power supply.
I am NOT connected to a PC using the mini USB port.
The board came without instructions on how to set it up. I followed all the links shown in the Quick Start Guide but I could find nothing about setting up WiFi (or anything else related specifically to the GHI board wireless board).
On bootup the first screen asked for a name and password.
For a new user, how would they know to use the standard debian name and password? (debian, temppwd)
On bootup I receive a dialog CMYS Warning Unable to find a systemtray on this machine. The program may still be used to manage your connections, but the icon will be disabled.
If you are seeing this message at startup and you know a
system tray exists once the system is up, try starting with the -w
switch and set a delay as necessary. The exact wait time will vary
from system to system.
Where is this setting set and what are the proper settings to use?
I found the Connman System Tray.
The Status Tab:
Global Properties
State: Idle
Offline Mode Disabled
Technologies:
Bluetooth and WiFi are Powered ON but not connected.
P2P is Off
Services List is empty.
Pressing the Rescan button shows a dialog.
CMTS Warning
We received a DBUS reply message indicating an error
while trying to scan technologies.
Error Name: org.freedeskstop.DBus.Error.NoReply.
Bla, bla, blaā¦
Wireless Tab:
I see WiFi Technologies: 1 Found, 1 Powered.
The Connect, Disconnect and Remove buttons are grayed out.
Iāll leave it at⦠HELP!:wall:
