Though I couldn’t find this mentioned in any New 4.0 posts, it appears you no longer need to add the FEZDomino_11_Pins.cs to any Domino projects…instead include the FEZDomino_GHIElectronics.NETMF.FEZ assembly/reference…
Correct me if I’m wrong…
I did this and it worked…though I had to change an analog pin from ‘A0’ to ‘AN0’ (LCD Shield)…
Still got exception so I recreated the entire project…didn’t investigate why…
How did we miss that! You are absolutely correct. That file was a fix for old SDK but you no longer need it and should not use it.
We have removed the download to that file
