Standard MF only allows for one IP interface. With 4.2, GHI has added support to allow multiple interfaces to exist on
a premium device. This is why the initialization sequence has changed.
At the present time, only one interface can be active. There is talk about allowing more than one to be
active in the future.
Thanks @ Mike. I now understand your answer, but I still think the “standard” way of accessing the network interface should work. The standard method also allows for more than one interface to exist.
With an OSHW device, the firmware is compiled to a specific hardware configuration. With the Premium devices, there is a bit more flexibility. For example, with the Spider you could use the built in PHY, or a SPI based Ethernet module. To use the standard interfaces they must have been initialized to specific hardware. I have not tried, but you might be able to use the standard interfaces once they have been assigned to an IP stack.
