Hi all,
I’m using a G120HDR board with ENC28 1.1 module and as a part of my project I try to implement a simple webserver. Unfortunately it does not become stable.
History:
First I tried several codeshare examples based on the HttpListener. The code every time works fine for a while and then hangs. I debugged and evaluate and found out, that the line “HttpListenerContext context = listener.GetContext();” stops after a random time (sometimes after some days) giving any result. I tried several suggestions from here and reinitialized everything step by step (listener the network) but nothing solved this issue.
To exclude side effects by all the other code, I already reduced the code to the webserver only, but still the same effect.
Then I lost trust in the HttpListener implementation (sorry) and decided to implement a simple socket based webserver instead. I disconnected the USB cable from the device and did a reset. It seemed to be stable, but after some days the webserver was not reachable anymore again.
I reconnected the USB and started debugging by attaching to the NETMF device.
Because in an interval I try to get NTP time via sockets, I get the event:
[quote] #### Exception System.Net.Sockets.SocketException - CLR_E_FAIL (4) ####
#### Message:
#### Microsoft.SPOT.Net.SocketNative::getaddrinfo [IP: 0000] ####
#### System.Net.Dns::GetHostEntry [IP: 0008] ####
#### G120_Home.Network.NtpTime::GetTime [IP: 000a] ####
#### G120_Home.Network.NtpTime::GetTime [IP: 001a] ####
#### G120_Home.Network.NtpTime::RefreshThread [IP: 0038] ####
#### SocketException ErrorCode = 10060
#### Exception System.NullReferenceException - CLR_E_NULL_REFERENCE (4) ####
#### Message:
#### G120_Home.Network.NtpTime::GetTime [IP: 0135] ####
#### G120_Home.Network.NtpTime::RefreshThread [IP: 0038] ####[/quote]
Disconnecting and connecting the Ethernet cable didn’t solve the problem. And then I tried something the first time and was absolutely surprised: I disconnected the ENC28 gadgeteer cable from the G120HDR board and reconnected it. Afterwards NTP time was received and the webserver was reachable again.
Now I need professional help to find the bug. I would guess, that the ENC28 board is defect but maybe there are other known reasons or experiences and I would be happy to hear about.
Additionally I found this post: “Resetting ENC28 network module after IP stack failure” and ask myself, whether the TCP/IP stack is unstable und if I will use it, what the indicator is to reinitialize the whole network interface. And it would be a workaround anyway and sounds dirty. If e.g. it is a known not solved problem for G120/ENC28 and solved for other modules, I would prefere to change the hardware. Is that an option? (I investigated already so much time, that it would be easier to switch)
I use Panda II as well in other projects with network connections and its running fine since many months. So it a challenge to get the G102 as stable as its small brother.
Thanks for support!
