I’m a bit new to this platform and experiencing the following problem:
I’m trying to setup a secure websocket (wss). This used to work on 4.2.11.0.
Now (4.3.6.0) I am getting a not supported exception from the SslNative class SecureClientInit(…).
So I have looked on the forum and see that I need to update ssl seed. So I tried using the FEZ Config -> Deployment (Advanced) -> Update SSL Seed button. When done, I still get the error.
Then I tried using the Microsoft deployment tool (C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Tools\MFDeploy.exe) It says:
Updating SSL seed…
Update Complete!
Still no success (I have restarted/repowered/… no change)
So I tried again and the tool said:
Updating SSL seed…
Created EE.
Update Complete!
I also have tried to add the certifciate (pxf) with it’s password but that didn’t change anything as well.
@ mrh4x - I would first try to completely reflash the board, including TinyBooter. If that doesn’t fix it, can you post a complete and minimal example that reliably reproduces the error?
I have tried Windows 7 and Windows XP and I am still unable to update the SSL seed.
The FEZ Config tool (and MSDeploy) both say that the Update SSL Seed has succeeded. After that I try to use SSL but it shows an error with the Native SSL stream.
@ mrh4x - It is quickest for us to work on the issue for you when you can post a minimal example that shows the issue reliably with nothing else in the project.
// connect to server
this.socket.Connect(this.serverEndpoint);
// get data stream
if (this.serverUri.Scheme == WSConst.SchemeWSS)
this.socketStream = new SslStreamEx(this.socket);
((SslStreamEx)this.socketStream).AuthenticateAsClient(this.serverUri.Host);
this.socketStream = new NetworkStream(this.socket, true);
// go to next state
this.subState = SubState.SendHandshake;
@ IwantToKnowItAll - I see you are using my Web Socket Client code from codeplex. The code you quoted in your comment above uses my SslStreamEx class, which is a thin wrapper around the Microsoft.SPOT.Net.Security.SslStream class.
A couple of months ago, I tried to upgrade this code to use NETMF 4.3, but ran into the same issue with the AuthenticateAsClient method.
public class SslStreamEx : Stream
#region Constructors and IDispose
public SslStreamEx(Socket socket)
this.sslStream = new SslStream(socket);
public void AuthenticateAsClient(string targetHost)
this.sslStream.AuthenticateAsClient(targetHost);
private SslStream sslStream;
Okay thanks for the reply. Does that mean that it’s just not possible anymore?
The thing is that I ran the websocket client once on 4.2 which worked (but not stable). So I upgraded to 4.3 and it seems now (even when going back to 4.2) it does not work anymore.
@ IwantToKnowItAll - It should work on 4.3. Perhaps someone on this forum will provide a suggestion. Regarding going back to 4.2, you need to downgrade everything (TinyBooter, the GHI firmware, all the project references, etc) in order to go back to 4.2. I think I tried that and it worked, but I’m not 100% sure.
@ IwantToKnowItAll - I’ve got the connectingthedots running over an SSL connection via AMQP and communicating with AzureServiceBus just kind of fine. I had that message as well and after an error return in MFDeploy SSL Feed update I tried to do it with FezConfig that returned in itself no response at all. Returning to MfDeploy and clicking the update again resulted in a Completed OK message.
After that it ran fine. I used the R5 SDK from GHI, so 4.3.6.0 netmf is on 4.3.1.0 and gadgeteer is on 2.43.1.0.
