In the past i used Microsoft.SPOT.Cryptography.Key_TinyEncryptionAlgorithm which was in 4.1. In 4.3 I seems to be missing something. Is there a compatible XTEA crypto? I need it to be able to decrypt Data encrypted with 4.1 devices.
Simply:
How do I perform XTEA Encryption and Decryption on a G400 running 4.3?
available in our utilities:
GHI.Utilities.Xtea
Namespace: GHI.Utilities
Assembly: GHI.Hardware (in GHI.Hardware.dll) Version: 4.3.4.0
follow the link to “GHI Extensions” on our support page:.NET Micro Framework – GHI Electronics
4.3.4.0 will drop very soon then ;D
Thanks will do.
In the past I used this:
private static readonly byte[] IntializationVector = new byte[] { 0, 0, 2, 2, 3, 4, 31, 25 };
//and
Key crypto = new Microsoft.SPOT.Cryptography.Key_TinyEncryptionAlgorithm(CryptoKey);
crypto.Encrypt(UnEncryptedBlocks, 0, 8, IntializationVector).CopyTo(CardBlocks, 20);
I don’t see a place to insert an Intialization Vector.
In GHI’s version what IV is used?
@ mPatterson557 - The IV in 4.1 was something specific to Microsoft’s full crypto implementation. XTEA itself does not use an IV so our implementation does not either.
Awesome thanks.
The IV is a pretty critical part of symmetric encryption. I suggest that you tack one on manually if security is important.
any thoughts on how to do that?
