Hello all,
I am working on a project with my Netduino Plus 2. I am encountering a strange problem.
In a nutshell, the device I’m designing is running tests on a circuit board to check for functionality. I am using the Netduino to send signals to this board. I have 6 push-buttons that trigger interrupts which send certain signals to the board being tested. If the correct level is detected at this board’s output pin, a corresponding LED is turned on. If an incorrect level is detected, the LED is flashed. The interrupt ports are interruptedgehigh with accompanying pull down resistors. The N+2 is being powered by 8 volts coming from a power supply circuit which itself is powered with your basic 120VAC.
The board I am testing requires 120VAC to be sent through 4 paths one at a time. This tests functionality of the components located on that particular path. So I have 4 line/neutral pairs sent to the board. But since the paths must be run one at a time, I have each line switched. This way, when I want to run the AC line tests, I flip line switch 1, press the test’s push-button to trigger the interrupt which runs the test, and then check the test results via the LED.
Now here is where my problem arises. My test seems to function correctly, but when I switch on the AC during any of the four AC line tests, either that test’s LED flashes or another AC line test’s LED flashes. So to be specific, let’s say I flip the switch to send AC through Line Test 1. No lights should turn on or flash until I press the push-button to trigger the interrupt. However, any of the four Line Test LED’s flash. It’s as if the interrupts are being triggered without the push-button being pressed.
I have included my entire program code below. I know this is long winded but I am just stumped as to a hardware cause and want to check all bases software wise before wracking my brain any further.
Attached is a wiring diagram of the circuit, as well as a picture of the front of the fixture. The AC lines are not included in the diagram because they are independent of the circuit. The fixture pic is to show where the ac switchers are in relation to the LEDs that continue to flash when the switches are flipped. Thanks so much for any and all help!
using System.Net;
using System.Net.Sockets;
using System.Diagnostics;
using SecretLabs.NETMF.Hardware;
using SecretLabs.NETMF.Hardware.Netduino;
namespace TLS_350_Pump_Sense_Module_Test_Program
private static InterruptPort LT1Switch = new InterruptPort(Pins.GPIO_PIN_D6, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
private static InterruptPort LT2Switch = new InterruptPort(Pins.GPIO_PIN_D7, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
private static InterruptPort LT3Switch = new InterruptPort(Pins.GPIO_PIN_D2, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
private static InterruptPort LT4Switch = new InterruptPort(Pins.GPIO_PIN_D3, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
private static InterruptPort TransTestSwitch = new InterruptPort(Pins.GPIO_PIN_D5, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
private static InterruptPort U1TestSwitch = new InterruptPort(Pins.GPIO_PIN_D4, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
private static OutputPort J1pin3 = new OutputPort(Pins.GPIO_PIN_D0, false);
private static InputPort J1pin4 = new InputPort(Pins.GPIO_PIN_D13, true, Port.ResistorMode.Disabled);
private static OutputPort J1pin5 = new OutputPort(Pins.GPIO_PIN_D9, false);
private static OutputPort J1pin7 = new OutputPort(Pins.GPIO_PIN_D10, false);
private static OutputPort J1pin9 = new OutputPort(Pins.GPIO_PIN_D11, false);
private static OutputPort J1pin10 = new OutputPort(Pins.GPIO_PIN_D12, true);
private static OutputPort LT1LED = new OutputPort(Pins.GPIO_PIN_D8, false);
private static OutputPort LT2LED = new OutputPort(Pins.GPIO_PIN_A1, false);
private static OutputPort LT3LED = new OutputPort(Pins.GPIO_PIN_A2, false);
private static OutputPort LT4LED = new OutputPort(Pins.GPIO_PIN_A3, false);
private static OutputPort TTLED = new OutputPort(Pins.GPIO_PIN_A4, false);
private static OutputPort U1TLED = new OutputPort(Pins.GPIO_PIN_A5, false);
private static DateTime lastEvent = DateTime.Now;
public static double ReadRaw()
AnalogInput TransistorTest = new AnalogInput(AnalogChannels.ANALOG_PIN_A0);
const double maxVoltage = 3.3;
const int maxADCValue = 4095;
double rawValue = TransistorTest.ReadRaw();
TransistorTest.Dispose();
double voltagevalue = (rawValue * maxVoltage) / maxADCValue;
double realworldvalue=(((voltagevalue - 0.5) * 1000) / 10) - 4;
return voltagevalue;
TransTestSwitch.OnInterrupt += new NativeEventHandler(TransTestSwitch_OnInterrupt);
LT1Switch.OnInterrupt += new NativeEventHandler(LT1Switch_OnInterrupt);
LT2Switch.OnInterrupt += new NativeEventHandler(LT2Switch_OnInterrupt);
LT3Switch.OnInterrupt += new NativeEventHandler(LT3Switch_OnInterrupt);
LT4Switch.OnInterrupt += new NativeEventHandler(LT4Switch_OnInterrupt);
U1TestSwitch.OnInterrupt += new NativeEventHandler(U1TestSwitch_OnInterrupt);
Debug.Print(ReadRaw().ToString("f"));
Thread.Sleep(300);
static void U1TestSwitch_OnInterrupt(uint data1, uint data2, DateTime time)
J1pin3.Write(false);
J1pin5.Write(true);
J1pin7.Write(false);
J1pin4.Read();
U1TestSwitch.ClearInterrupt();
if (time.AddMilliseconds(-500) > lastEvent)
lastEvent = time.AddMilliseconds(500);
if (J1pin4.Read() == true)
U1TLED.Write(true);
int U1number = 7;
for (int i = 0; i < U1number; i++)
U1TLED.Write(true);
Thread.Sleep(200);
U1TLED.Write(false);
Thread.Sleep(200);
static void TransTestSwitch_OnInterrupt(uint data1, uint data2, DateTime time)
J1pin3.Write(true);
J1pin5.Write(true);
J1pin7.Write(true);
J1pin9.Write(true);
ReadRaw();
TransTestSwitch.ClearInterrupt();
if (ReadRaw() > 2.4 && ReadRaw() <= 2.7)
TTLED.Write(true);
Thread.Sleep(300);
int Tnumber = 7;
for (int i = 0; i < Tnumber; i++)
TTLED.Write(true);
Thread.Sleep(200);
TTLED.Write(false);
Thread.Sleep(200);
static void LT1Switch_OnInterrupt(uint data1, uint data2, DateTime time)
J1pin5.Write(false);
J1pin4.Read();
LT1Switch.ClearInterrupt();
if (J1pin4.Read() == false)
LT1LED.Write(true);
int L1number = 7;
for (int i = 0; i < L1number; i++)
LT1LED.Write(true);
Thread.Sleep(200);
LT1LED.Write(false);
Thread.Sleep(200);
static void LT2Switch_OnInterrupt(uint data1, uint data2, DateTime time)
J1pin3.Write(true);
J1pin4.Read();
LT2Switch.ClearInterrupt();
LT2LED.Write(true);
int L2number = 7;
for (int i = 0; i < L2number; i++)
LT2LED.Write(true);
Thread.Sleep(200);
LT2LED.Write(false);
Thread.Sleep(200);
static void LT3Switch_OnInterrupt(uint data1, uint data2, DateTime time)
J1pin5.Write(true);
J1pin4.Read();
LT3Switch.ClearInterrupt();
LT3LED.Write(true);
int L3number = 7;
for (int i = 0; i < L3number; i++)
LT3LED.Write(true);
Thread.Sleep(200);
LT3LED.Write(false);
Thread.Sleep(200);
static void LT4Switch_OnInterrupt(uint data1, uint data2, DateTime time)
J1pin3.Write(true);
J1pin5.Write(true);
J1pin4.Read();
LT4Switch.ClearInterrupt();
LT4LED.Write(true);
int L4number = 7;
for (int i = 0; i < L4number; i++)
LT4LED.Write(true);
Thread.Sleep(200);
LT4LED.Write(false);
Thread.Sleep(200);
