Hello John,
Thanks for your quick response.
I obtained the following:
PS C:\Work\Netduino\GitHub_repos\TinyCLR-Ports> .\build.bat netduino3
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Startup.gcc.s
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_ADC.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_ADC.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4.h:66:77: error: ‘TinyCLR_Power_Level’ has not been declared
TinyCLR_Result STM32F4_Power_SetLevel(const TinyCLR_Power_Controller* self, TinyCLR_Power_Level level, TinyCLR_Power_WakeSource wakeSource, uint64_t data);
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4.h:66:104: error: ‘TinyCLR_Power_WakeSource’ has not been declared
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_CAN.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_CAN.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_CAN.cpp:338:46: error: ‘STM32F4_CAN_PINS’ was not declared in this scope
static const STM32F4_Gpio_Pin canPins[][2] = STM32F4_CAN_PINS;
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_CAN.cpp:338:46: note: suggested alternative: ‘STM32F4_PWM_PINS’
STM32F4_PWM_PINS
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_DAC.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_DAC.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Deployment.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Deployment.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Display.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Display.cpp:18:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_GPIO.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_GPIO.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_I2C.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_I2C.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_I2C.cpp:25:46: error: ‘STM32F4_I2C_PINS’ was not declared in this scope
static const STM32F4_Gpio_Pin i2cPins[][2] = STM32F4_I2C_PINS;
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_I2C.cpp:25:46: note: suggested alternative: ‘STM32F4_PWM_PINS’
STM32F4_PWM_PINS
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Interrupt.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Interrupt.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp: In function ‘void STM32F4_Power_EnsureTableInitialized()’:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:43:29: error: ‘struct TinyCLR_Power_Controller’ has no member named ‘SetLevel’
powerControllers[i].SetLevel = &STM32F4_Power_SetLevel;
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp: At global scope:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:73:77: error: ‘TinyCLR_Power_Level’ has not been declared
TinyCLR_Result STM32F4_Power_SetLevel(const TinyCLR_Power_Controller* self, TinyCLR_Power_Level level, TinyCLR_Power_WakeSource wakeSource, uint64_t data) {
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:73:104: error: ‘TinyCLR_Power_WakeSource’ has not been declared
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp: In function ‘TinyCLR_Result STM32F4_Power_SetLevel(const TinyCLR_Power_Controller*, int, int, uint64_t)’:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:75:10: error: ‘TinyCLR_Power_Level’ has not been declared
case TinyCLR_Power_Level::Sleep1: // Sleep
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:76:10: error: ‘TinyCLR_Power_Level’ has not been declared
case TinyCLR_Power_Level::Sleep2: // Sleep
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:77:10: error: ‘TinyCLR_Power_Level’ has not been declared
case TinyCLR_Power_Level::Sleep3: // Sleep
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:78:10: error: ‘TinyCLR_Power_Level’ has not been declared
case TinyCLR_Power_Level::Off: // Off
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:79:10: error: ‘TinyCLR_Power_Level’ has not been declared
case TinyCLR_Power_Level::Custom: // Custom
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:83:10: error: ‘TinyCLR_Power_Level’ has not been declared
case TinyCLR_Power_Level::Active: // Active
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Power.cpp:84:10: error: ‘TinyCLR_Power_Level’ has not been declared
case TinyCLR_Power_Level::Idle: // Idle
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_PWM.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_PWM.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_RTC.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_RTC.cpp:15:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_SD.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_SD.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_SPI.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_SPI.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_SPI.cpp:33:46: error: ‘STM32F4_SPI_PINS’ was not declared in this scope
static const STM32F4_Gpio_Pin spiPins[][3] = STM32F4_SPI_PINS;
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_SPI.cpp:33:46: note: suggested alternative: ‘STM32F4_GPIO_PINS’
STM32F4_GPIO_PINS
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Startup.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Startup.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Time.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_Time.cpp:17:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UART.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UART.cpp:18:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UART.cpp:75:47: error: ‘STM32F4_UART_PINS’ was not declared in this scope
static const STM32F4_Gpio_Pin uartPins[][4] = STM32F4_UART_PINS;
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UART.cpp:75:47: note: suggested alternative: ‘STM32F4_UART_TX_PINS’
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UsbDevice.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UsbDevice.cpp:18:0:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UsbDevice.cpp:245:52: error: ‘STM32F4_USB_PINS’ was not declared in this scope
static const STM32F4_Gpio_Pin usbDevicePins[][4] = STM32F4_USB_PINS;
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx\STM32F4_UsbDevice.cpp:245:52: note: suggested alternative: ‘STM32F4_PWM_PINS’
STM32F4_PWM_PINS
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Devices\netduino3\Device.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Devices\netduino3\Device.h:19:0,
from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Devices\netduino3\Device.cpp:1:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx/STM32F4.h:66:77: error: ‘TinyCLR_Power_Level’ has not been declared
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Targets\STM32F4xx/STM32F4.h:66:104: error: ‘TinyCLR_Power_WakeSource’ has not been declared
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Main\main.cpp
In file included from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Devices\netduino3/Device.h:19:0,
from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Main\main.cpp:16:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\USBClient\USBClient.cpp
from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\USBClient\USBClient.h:19,
from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\USBClient\USBClient.cpp:18:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\GHIElectronics_TinyCLR_InteropUtil.cpp
from C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\GHIElectronics_TinyCLR_InteropUtil.cpp:16:
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\Adc\GHIElectronics_TinyCLR_Devices_Adc.cpp
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\Adc\GHIElectronics_TinyCLR_Devices_Adc_GHIElectronics_TinyCLR_Devices_Adc_Provider_AdcControllerApiWrapper.cpp
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\Can\GHIElectronics_TinyCLR_Devices_Can.cpp
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\Can\GHIElectronics_TinyCLR_Devices_Can_GHIElectronics_TinyCLR_Devices_Can_Provider_CanControllerApiWrapper.cpp
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\Dac\GHIElectronics_TinyCLR_Devices_Dac.cpp
C:\Work\Netduino\GitHub_repos\TinyCLR-Ports\Drivers\DevicesInterop\Dac\GHIElectronics_TinyCLR_Devices_Dac_GHIElectronics_TinyCLR_Devices_Dac_Provider_DacControllerApiWrapper.cpp
