Trying to port an App from .NETMF to TinyCLR v1.0.0 is saw that the App didn’t run in TinyCLR.
As the reason I found that the declaration of a string led to different results in .Net (.NETMF behaved the same way) and TinyCLR.
string tableName = "TableSample";
string _accountAccountName = "MyAccount";
DateTime InstanceDate = DateTime.Now;
string content = "<?xml version=\"1.0\" encoding=\"utf-8\" standalone=\"yes\"?>" +
"<entry xmlns:d=\"http://schemas.microsoft.com/ado/2007/08/dataservices\" " +
"xmlns:m=\"http://schemas.microsoft.com/ado/2007/08/dataservices/metadata\" " +
"xmlns=\"http://www.w3.org/2005/Atom\"> " +
"<id>http://" + _accountAccountName + ".table.core.windows.net/Tables('"
+ tableName +
"')</id>" +
"<title />" +
"<updated>" + InstanceDate.ToString("yyyy-MM-ddTHH:mm:ss.0000000Z") + "</updated>" +
"<author><name/></author> " +
"<content type=\"application/xml\"><m:properties><d:TableName>" + tableName + "</d:TableName></m:properties></content></entry>";
string strCopy = content; // (breakpoint)
In .Net the result was a well formed xml. In TinyCLR the string was truncated.
As I always thought that two contradictory statements cannot both be true…? Whats on here? Different handling of escape sequences? Which result is correct?
