About a week ago I bought a FEZ Cerebus.
I’m very excited about it, but now I want to create a my own board. It should be very small and consume little power.
I have already gained experience with DFU, TinyBooter and ST-Link.
Now I found the chip STM32F411CC (WLCSP49) and wonder whether the .NET MF can be installed on this processor, without recompiling the MF…
@ misaro - you will need to change a few files to suite the package - ie ram and flash size and pin mappings etc.
Since you are running with so little resources you will also need to compile the firmware with MDK or similar as i am fairly sure GCC will produce a binary which is too large.
So in essence you will need to change the following files:
Word of caution - unless your are strong in the art of PCB Fu you will struggle to use the WLCSP-49 package as you are talking about 0.4mm ball pitch which will require filled VIP’s etc which will require expensive PCB’s. Also you will need to place some 0.1uF’s on the back side of the PCB which although not difficult will require more manufacture steps.
You maybe a PCB Ninja with a pocket full of cash so you can happily ignore the above
Attached is an image of the 64 pint Cerb STM, the 7mm QFN that i like using and the WLCSP-49 package - you can see that the 0.2mm hole via doesn’t fit in between balls hence the need from VIP’s
If you are the mad scientist and do go marching off into the sunset and create a PCB running a WLCSP-49 please document the process as that would be very cool and i would happily supply a binary for it
@ Justin - Hehe thanks. Yep, WLCSP49 (15.47 mil / 0.4mm pitch) is fu** small! But that’s not the problem here, designing PCB is part of my job And the best part: My colleague works at a PCB manufacturer. They can produce their own boards, even for private purpose.
