I’m new here at this forum and hope I get a good start here. I want to develop my own Software, for my house automation build with Enocean parts.
My question:
is it possible to use this part (TCM310 Modul) with any of the .NET Gadgeteer Boards?
For that I’ll use the FEZ Cerbuino.
Thanks for your answer.
Greetz Mic
Hi and welcome to the forum!
Looks like a standard UART device. So that should make it easy to connect to ! You will need to know the serial parameters like baud rate, as well as the serial commands the module uses, but the connection aspect should be fine.
Thanks for the reply. I know all the specs like baud rate etc. Only the possibility about the connection was unclear.
