Davef
May 9, 2012, 1:09pm
1
I am getting this error,
Exception System.Exception - CLR_E_DRIVER_NOT_REGISTERED (2)
#### Message:
#### Microsoft.SPOT.Hardware.NativeEventDispatcher::.ctor [IP: 0000] ####
#### GHIElectronics.NETMF.System.InternalEvent::.cctor [IP: 0014] ####
An unhandled exception of type ‘System.Exception’ occurred in Microsoft.SPOT.Hardware.dll
When using this code for an SPI instance.
//GT = Gadgeteer
GT.Socket socket = GT.Socket.GetSocket(3, false, null, null);
SPI.Configuration SpiConfiguration = new SPI.Configuration(false, 2, 2, false, true, 1000);
SPI.Sharing shared = new SPI.Sharing();
SPI SpiCom = new SPI(socket, SpiConfiguration, shared, socket, GT.Socket.Pin.Five, null);
SpiCom.WriteRead(WriteBuffer, ReadBuffer);
Is my code correct or am I bouncing off the walls?
What references do you have added to your project? It looks like you may be using a non-OSH assembly, which is usually the cause of this error.
I just have to ask this. Is firmware on the board and installed SDK in sync?
Davef
May 10, 2012, 11:50am
4
Guys, Solved it!
I was using the gadgeteer template, and placed the SPI instance within ProgramStarted(). I am now using a standard class template and not getting any errors. Its nice to see that SPI has a shared method, so why cant we have the same for I2C, which is also a buss?
@ Steven, I can only find 2 OSH refs should there be more?
@ Architect, Good call, but I updated my Hydra a few days ago!
Davef
May 10, 2012, 2:10pm
5
Sorry its not solved! It appears to be ok when using the emulator, but when I change to USB I get the above error.
@ Steven I am using:
using System.Collections;
using GHIElectronics.OSH.NETMF.Hardware;
using GHIElectronics.OSH.NETMF.Native;
using Gadgeteer;
using Gadgeteer.Interfaces;
using GT = Gadgeteer;
in my program, and
Gadgeteer
GHIElectronics.Gadgeteer.FEZHydra
GTM.GHIElectronics.UsbClientDP
Microsoft.SPOT.Native
references.
Is not supposed to be there.
Davef
May 10, 2012, 2:21pm
7
@ Architect, Excellent thats fixed it, but now, how do I use trig functions?
Mike
May 10, 2012, 2:28pm
8
System.Math?
**** Oooops. I thought there were trig functions there.
This project has some functions,but I don’t see the code there
http://www.tinyclr.com/codeshare/entry/149
Something is broken on codeshare for this one after the recent update.
I have a math lib here.
http://netmfx.codeplex.com/
Also, I think I read that 4.2 was adding a lot of the trig functions. I haven’t explored that yet, though.
Davef
May 10, 2012, 2:55pm
11
I have a copy of Grommet somewhere I will dig that out. I’m sure that has Trig functions, it just makes it a bit messy. Thanks for the help!
Davef
May 10, 2012, 3:15pm
12
Math.cs from Grommet works fine! Thanks again!
You are welcome!
What are you working on, just curious?
Davef
May 10, 2012, 3:44pm
14
@ Architect,
I’m not focused on anything at the moment. I get so much pleasure form just connecting sensors etc, to a uC and getting something working, normaly without an end product in mind. Yeah I know I need to get a life, but it keeps me happy. I am sure I will fly a Panda II, with the help of an STM32F103, buts that will be at least 3 - 4 months when I have enough spare cash, and if I dont lose intrest.
I see. As long as you having fun like the rest of us. Good luck with your projects!
