OK, So I am a late bloomer to this stuff maybe, but,
I ordered the FEZ Spider board and was so excited.
I followed the instructions for downloading and install.
Went to the tutorials to start my first project,
And boom, first thing off the bat, the FEZ HYDRA shows up in the no modules in the toolbox.
So I cant change the motherboard…
Then I select Show All in the toolbox, and there are most of the modules, along with 5000 other items.
In C# Express they dont even show up.
I fiddled around and got some things to work that way, but the software side of the product is still not as advertised.
I have uninstalled rebooted, reinstalled twice now with no help.
So on your second image, the new project, it seems you have the Gadgeteer and Netmf project types. But the list of templates under the Gadgeteer folder looks completely wrong.
So I suggest you uninstall the GHI SDK, then uninstall the netmf SDK, and then try loading that all again. But as Architect asked, can you please confirm the filename of the two SDKs you installed?
Can you tell us if you ever had VC# installed before, or did you install that fresh too?
Brett,
Thanks. I did remove and reinstall in the order on the install page for 4.2.
Rebooted, and that worked.
My version of VS Ultimate has been on for a few years now. However VC Express is new with SP1.
I removed everything rebotted, andnow it is working fine.
