I cannot figure out how to get my program to work.
Here’s my code:
using System.Collections;
using Microsoft.SPOT.Touch;
using Gadgeteer.Networking;
using GT = Gadgeteer;
namespace DebugTest
public partial class Program
timer.Tick +=<tab><tab>
timer.Start();
Every time I try to debug for my G400HDR I get the following error:
[quote]Found debugger!
Create TS.
Loading start at 202cf300, end 202fe2c8
Assembly: mscorlib (4.2.0.0) Assembly: Microsoft.SPOT.Native (4.2.0.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.2
.0.0) Assembly: System.Security (4.2.0.0) Assembly: Microsoft.SPOT.Hardware (4.2.0.0)
Assembly: Microsoft.SPOT.Graphics (4.2.0.0) Assembly: Microsoft.SPOT.TinyCore (4.2.0.0)
Assembly: Microsoft.SPOT.IO (4.2.0.0) Assembly: System.IO (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0) Assembly: Microsoft.SPOT.Touch (4.2.0.0)
Assembly: Microsoft.SPOT.Ink (4.2.0.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)
Attaching deployed file.
Assembly: Gadgeteer (2.42.0.0) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.42.0.0) Attaching deployed file.
Assembly: Gadgeteer.Serial (2.42.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.2.0.0) Attaching deployed file.
Assembly: dotnetwarrior.Gadgeteer.G400HDR (1.1.1.0) Attaching deployed file.
Assembly: Gadgeteer.DaisyLink (2.42.0.0) Attaching deployed file.
Assembly: DebugTest (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Breakout (4.2.101.0) Resolving.
Assembly: dotnetwarrior.Gadgeteer.G400HDR (1.1.1.0) needs assembly ‘GHI.Premium.Hardware’ (4.2.11.0)
Assembly: dotnetwarrior.Gadgeteer.G400HDR (1.1.1.0) needs assembly ‘GHI.Premium.System’ (4.2.11.0)
Assembly: DebugTest (1.0.0.0) needs assembly ‘dotnetwarrior.Gadgeteer.G400HDR’ (1.1.1.0)
Error: a3000000
Waiting for debug commands…
The program ‘[8] Micro Framework application: Managed’ has exited with code 0 (0x0).[/quote]
I have already completely re installed all of the .NET SDK’s and NETMF stuff. I have no idea what to do.
I should point out that the reason my code is only the starting code is because I am simply trying to get the debugger to work in the first place. All i want to do is be able to debug.
