I am trying to use the bitmap TileImage method…WHERE is the info on this?
I can’t find ANYTHING on Google, this forum or even the .netmf microframe SDK help…where is the info at? This seems quite strange
There is tile image method? I never seen it
Yes, after fiddling around I got it working, I just had to guess at what a few parameters did…make the first two values zero!
Still, strange, I can’t find ANY mention about this ANYWHERE…???
Did you check Microsoft API online?
[quote]
Did you check Microsoft API online?[/quote]
I checked MSDN & the SDK…found virtually nothing!
