what i need is a small, cheap and easy to program GPS. I need to be able to read position (latitude / longitude) and altitude and compare it to preprogramed one and display distance to preprogramed place. And finally actiwate motor when point is reached.
soldering is not a problem at all. But i like the idea of $20, since i’m on the budget. How hard it will be to pull neede data of gps unit like one that comes with misrosoft maps?
And with FEZ will be best for me. I would like to put that into rather small box but all of them seams to be pretty small.
I was thinking about FEZ Mini. Is that USB for programming only? Or can be use ti recive data from gps.
I looked into displays to. I realy need only 2x16 Character LCD but Serial LCD seams to be easier and if i would go with Serial LCD than Graphical 3.6" 128x64 Display is not much more? what wuld be easiest?
So usb is not the way to go. In this case I think that fez mini will be my choice. Chris with of gps unit you think will be best overall. One of the 2 that you recommended (if yes with), one from this website or maybe you have your own recommendation?
