I need to read the first 4 bytes of a server response to determine the actual length of the packet. It works if i use it in the full framework using BitConverter.ToInt32, but when i’m using the Utility.ExtractValueFromArray(length, 0, 4); i’m getting a whole nother result
Can Someone look at my code please
private static Boolean CheckPacket(Byte[] buffer)
Byte[] length = new Byte[4];
Array.Copy(buffer, length, 4);
UInt32 packetLength = Utility.ExtractValueFromArray(length, 0, 4);
Debug.Print("buffer: " + buffer.Length + " packet: " + packetLength);
return buffer.Length == packetLength;
private void ProcessDeviceRequest()
Socket socket = _tcpSocket;
try
Byte[] buffer = null;
// Wait for the client request to start to arrive.
const Int32 microsecondsPerSecond = 1000000;
if (!socket.Poll(5*microsecondsPerSecond, SelectMode.SelectRead)) continue;
Byte[] inBuffer = new byte[2048];
Int32 bytesRead = socket.Receive(inBuffer, socket.Available, SocketFlags.None);
if (bytesRead == 0) break;
if (buffer == null)
buffer = new byte[bytesRead];
Array.Copy(inBuffer, buffer, bytesRead);
if (CheckPacketAndSend(buffer))
break;
buffer = ConcatArray(buffer, buffer.Length, inBuffer, bytesRead);
break;
catch (Exception ex)
if (!(ex is SocketException))
Debug.Print("Socket exception client");
The code above handles the response from the server. The CheckPacket is used in this code
private Boolean CheckPacketAndSend(Byte[] buffer)
if (CheckPacket(buffer))
_request = RemovePrefix(buffer);
_request = _request.Trim();
String remote = GetRemote(_tcpSocket);
Debug.Print("Device request from " + remote + ": [" + _request + "]");
new Thread(SendOutputDeviceResponse).Start();
return true;
return false;
This is the result i get using the Utility.ExtractValueFromArray(length, 0, 4);
buffer: 1460 packet: 436600832
buffer: 1566 packet: 436600832
Thanx in advance.
