Need help hooking up Audio Codec board based on the VS1063
Need some help reading the datasheet and hooking up the Audio Codec board I have on my desk…
I have made a library (converted from C) with all the commands this baby can do, so if anyone could help getting it hooked up correct, I could continue making a driver for a kick ass Audio board with some nice features ;D
Here is the board: https://www.sparkfun.com/products/11684
Schematics for the board is all there, and the datasheet for the VS1063a audio chip.
We are going to use it to convert realtime audio from TCP/IP packages over to analog audio, and back again… going to function a bridge between VOIP packages and analog audio in/out. But it has so much more to show off, so a driver could benifit more people in the community if we get this baby up and running.
I have a couple of Breakout boards and BreadBoard modules… so its a matter of getting the pins from the Codec board connected to the right stuff on a socket or two (depending on how many we might need)
Maybe this can help in case you didn’t see it:
https://www.ghielectronics.com/community/codeshare/entry/313
@ Jay Jay - thanks. Peeked on the code found in Code Share… It seems to work pretty good. Audio quality ain’t that bad either, it’s actually quite good ;D
Audio clip from Resources
And MP3 from SD card
