I don’t suppose we could get, or is there already a native CRC function? CRC16 would be dandy.
Are you planning to add crc32 implementation?
We actually already have it internally. Not sure why we didn’t expose it.
Please expose it.
Are you expose native crc32 in release 2.0 ?
Can you use MD5 or your project require has to be CRC?
I was planning to use CRC
Sorry, it is too late in v2.0.0.
In 2.0.1 maybe?
99% is Yes.
Why not use md5?
in managed code
//https://stackoverflow.com/questions/8128/how-do-i-calculate-crc32-of-a-string?noredirect=1&lq=1
namespace TinyCLRCRC32
class CRC32
private uint[] ChecksumTable;
private uint Polynomial = 0xEDB88320;
public CRC32()
ChecksumTable = new uint[0x100];
for (uint index = 0; index < 0x100; ++index)
uint item = index;
for (int bit = 0; bit < 8; ++bit)
item = ((item & 1) != 0) ? (Polynomial ^ (item >> 1)) : (item >> 1);
ChecksumTable[index] = item;
public byte[] ComputeHash(byte[] stream)
UInt32 result = 0xFFFFFFFF;
int current;
for (int i = 0; i < stream.Length; i++)
current = stream[i];
result = ChecksumTable[(result & 0xFF) ^ (byte)current] ^ (result >> 8);
byte[] hash = BitConverter.GetBytes(~result);
byte[] reverseHash = Reverse(hash);
return Reverse(reverseHash);
private byte[] Reverse(byte[] Array)
byte[] toReverse = new byte[Array.Length];
int j = 0;
for (int i = Array.Length - 1; i >= 0; i--)
toReverse[j] = Array[i];
j++;
return toReverse;
usage
using System.Diagnostics;
using System.Text;
class Program
static void Main()
Debug.WriteLine("CRC32 Test 1!");
var crc = new CRC32();
// Convert a C# string to a byte array
string author = "Valon Hoti";
////convert binary file to byte[] ...
byte[] bytes = Encoding.UTF8.GetBytes(author);
string myRes = "";
foreach (byte s in crc.ComputeHash(bytes))
myRes += s.ToString("x2").ToUpper();
Debug.WriteLine(myRes); //need to reverse it because MCU and DESKTOP act differently
Debug.WriteLine(stringReverseString(myRes));
while(true)
public static string stringReverseString(string str)
char[] chars = str.ToCharArray();
for (int i = 0, j = str.Length - 1; i < j; i++, j--)
char c = chars[i];
chars[i] = chars[j];
chars[j] = c;
return new string(chars);
REMARKS.
**TESTED ON DESKTOP AND TINYCLR but results are different **
CODE
string myRes = "";
gave
result : 770B5A89 on DESKTOP
result: 895A0B77 on TINYCLR
after i add stringReverseString to correct it
but slower than native
Correct but SITCore is 30 times faster than G120
In 2.1.0 - Preview1 I can’t find native crc32 implementation
It is Crc16 only for now.
var crc16 = new Crc16();
var data = new byte[] { 1, 2, 3, 4, 5, 6, 7, 8 };
var crcVal1 = crc16.ComputeHash(data, 0, data.Length);
var crcVal2 = crc16.ComputeHash(data, 0, data.Length);
crc16.Reset();
var crcVal3 = crc16.ComputeHash(data, 0, data.Length); // After Reset(), crcVal3 same as crcVal1
Maybe we will add CRC32 but we now have CRC16 for fast needs and MD5 for robust needs. Why is the need for CRC32?
I use it in old projects to control the integrity of the coefficients stored in EEPROM
Then why not use MD5? I am just curious here.
