I have my code running on ChipX.
Now how do I make it run native. So it can be faster
Search for “RLP” on this forum and documentation.
I searched and do not see anything usefull. Like sample code or doc.
WOuld you point me to it
See fezzer for my example
So I see this code on feezer. But no explanation.
So is my assumption correct.
The first function below is c or cpp.
And is a seperate project or can it be in the same project?
How do I cross compile it for the ChipX.
Then this arm elf file is used like a dll by the .NET MF C# code.
And wher is the parameters for the function passed?
// Include RLP
#include <RLP.h>
// Add 29 + 92 and return
int Add_c(unsigned int *generalArray, void **args, unsigned int argsCount, unsigned int *argSize)
return 29 + 92;
using GHIElectronics.NETMF.Native;
namespace RLPTest
// Load ELF in byte array
byte[] elfFile = Resources.GetBytes(Resources.BinaryResources.Hello_World);
// Load ELF to RLP
RLP.LoadELF(elfFile);
RLP.InitializeBSSRegion(elfFile);
// Ge the procedure
RLP.Procedure add = RLP.GetProcedure(elfFile, "Add_c");
// Invoke it
Debug.Print(add.Invoke().ToString());
The docs explain it all with code examples. Do not use the fezzer example to get started.
Are you trying to convert your managed code to unmanaged code?
Gus, which docs explains it all? Is it too much trouble to post a link?
Click on
Help → GHI netmf lib
on top menu
http://www.ghielectronics.com/downloads/NETMF/Library%20Documentation/Index.html
Then find RLP class
