Hi
I’m having a problem where my application stops receiving interrupts from an extender module. It seems to always be after the garbage collector has run. If i do a number of updates on the display, the GC always run. Curious on both why the interrupts stop, and why the collector runs so often when updating the display. Perhaps this is normal?
The following code:
int i = 0;
Font smallFont = Resources.GetFont(Resources.FontResources.NinaB);
while (i<100)
i++;
display_N18.SimpleGraphics.Clear();
display_N18.SimpleGraphics.DisplayText("Testprint"+i.ToString(),smallFont,Color.White,5,5);
Debug.Print("Printed nr:"+i);
Debug.Print("Program Ended..");
will generate the output:
(…cut the beginning and end from output…)
Printed nr:24
Printed nr:25
GC: 3msec 559716 bytes used, 6779952 bytes available
Type 0F (STRING ): 552 bytes
Type 11 (CLASS ): 9084 bytes
Type 12 (VALUETYPE ): 1068 bytes
Type 13 (SZARRAY ): 43956 bytes
Type 03 (U1 ): 41160 bytes
Type 04 (CHAR ): 636 bytes
Type 06 (U2 ): 24 bytes
Type 07 (I4 ): 756 bytes
Type 0F (STRING ): 48 bytes
Type 11 (CLASS ): 1332 bytes
Type 15 (FREEBLOCK ): 6779952 bytes
Type 16 (CACHEDBLOCK ): 24 bytes
Type 17 (ASSEMBLY ): 27444 bytes
Type 18 (WEAKCLASS ): 96 bytes
Type 19 (REFLECTION ): 192 bytes
Type 1B (DELEGATE_HEAD ): 360 bytes
Type 1D (OBJECT_TO_EVENT ): 264 bytes
Type 1E (BINARY_BLOB_HEAD ): 470208 bytes
Type 1F (THREAD ): 768 bytes
Type 20 (SUBTHREAD ): 96 bytes
Type 21 (STACK_FRAME ): 1968 bytes
Type 27 (FINALIZER_HEAD ): 192 bytes
Type 28 (MEMORY_STREAM_HEAD ): 36 bytes
Type 29 (MEMORY_STREAM_DATA ): 396 bytes
Type 31 (IO_PORT ): 252 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 2688 bytes
Printed nr:26
Before reaching 100 the GC runs 3 times. The program and display updates continue to run to completion.
Regards
/John
