Is it possible to rotate the screen orientation with N18 on a Spider?
The manual pages (https://www.ghielectronics.com/community/forum/topic/create?id=21) say that you must use the special function Util.SetSpecialDisplayConfig for Cerberus, but what about Spider?
Because when I try to call:
I get the runtime error:
Program ExampleSpider, Version=1.0.0.0 starting...
#### Exception System.InvalidOperationException - 0x00000000 (1) ####
#### Message: Cannot set LCD rotation on displays that are not LCD controller based
#### Gadgeteer.Modules.Module+DisplayModule::SetLCDRotation [IP: 000f] ####
#### ExampleSpider.Program::Main [IP: 0015] ####
A first chance exception of type 'System.InvalidOperationException' occurred in Gadgeteer.dll
An unhandled exception of type 'System.InvalidOperationException' occurred in Gadgeteer.dll
NB. This is a configuration with TWO displays, a T35 and a single N18. I presume it IS possible to run two displays at once?
