I’m using the latest sdk 4.2.10.1. Can you show your code?
@ Patrick -
Private Sub SetupNet()
AddHandler ethernet.Interface.CableConnectivityChanged, AddressOf _CableConnectivityChanged
AddHandler ethernet.Interface.NetworkAddressChanged, AddressOf _NetworkAddressChanged
ethernet.Interface.Open()
If Not (ethernet.Interface.IsActivated) Then
GHI.Premium.Net.NetworkInterfaceExtension.AssignNetworkingStackTo(ethernet.Interface)
End If
ethernet.Interface.NetworkInterface.EnableDhcp()
ethernet.UseDHCP()
End Sub
Private Sub _CableConnectivityChanged(sender As Object, e As GHI.Premium.Net.EthernetBuiltIn.CableConnectivityEventArgs)
If ethernet.Interface.IsCableConnected Then
debugging.Print(DateTime.Now.ToString + ": cable connected")
ethernet.UseDHCP()
Else
debug.Print(DateTime.Now.ToString + ": cable lost")
End If
End Sub
Private Sub _NetworkAddressChanged(sender As Object, e As EventArgs)
debug.Print(DateTime.Now.ToString + ": new IP --> " + ethernet.NetworkSettings.IPAddress.ToString)
If ethernet.NetworkSettings.IPAddress = "0.0.0.0" Then
'code when network down
Else
'code when network up and ip received
NtpTimeRequest()
End If
End Sub
@ VB-Daniel -
Your code compared with mine is comparable. I’ve got some additional code to determine the use of dhcp or fixed ip. I’ll post it tomorrow.
@ Patrick - maybe the fixed ip is the problem, don’t see it again since the static code is deleted.
