Forgive me for being a hardware idiot however i’ve been searching and i’m not sure if you can wire the USB busses like other busses such as I2C.
Is it possible to run multiple USB ports of one EMX like in the diagram attached.
Ooops I see a problem with port 1 on the lower USB port already. Use this image.
You can’t do that. You need a USB hub.
Is there anyway to add two USB Host ports without an additional controller?
